difference 1998 & 2002 LS1 blocks
Old Mar 20, 2005 | 06:30 PM
general23cmp's Avatar
Default difference 1998 & 2002 LS1 blocks
I have heard that the block for the past few years has been the same for both LS1 and LS6 engines. What would be the difference in a 1998 (for example) and a 2002 (for example) LS1 block? I am looking to build up an LS1, and have access to an "older" block, but I want to get the best for the task. What would be the other differences, not block specific, between the two?
Thanks guys...
Old Mar 20, 2005 | 08:44 PM
Another_User's Avatar
Thanks guys...
98s are the only year that cannot be bored at all. They can take a light honing, other than that and they will need a re-sleeve. I am not aware of differences in any other year blocks.
Old Mar 20, 2005 | 09:50 PM
ChucksZ06's Avatar
Quite a few of the 02 blocks are actuallly ls6 blocks with the open webs at the main webs for better oil control from bay to bay and are worth a few hp at high rpms. You can tell by the number stamped on the back of the block.
Old Mar 20, 2005 | 10:12 PM
Casperws6's Avatar
check jrp's sig.. that will answer ALL your questions
Old Mar 20, 2005 | 10:16 PM
Casperws6's Avatar
let me help u
https://ls1tech.com/forums/showpost....80&postcount=2
