LS1 , Cubic inch question
Old Mar 23, 2005 | 12:19 PM
datsbad's Avatar
Default LS1 , Cubic inch question
hello . i am building a 69 camaro convertible. i plan to use either a magnacharger or a turbo. i would like to have at least 600hp . i do not however want a stock ls1 displacement . i am wondering what to use . could anyone give me some insight on a combination to use with this . heads , cam , rotating assembly, etc...
please give me some advice from experience , thanks
Old Mar 23, 2005 | 12:31 PM
777's Avatar
777
if you want to use an ls1 block i would go 383 (same bore, stroker crank) if you want an ls2 (aluminum) or lq9 (iron) you can do a 402-408...you could also resleeve the ls1 for a 427 big$$$ or get a c5r block real big $$$ like 6,000 for block alone
Old Mar 23, 2005 | 01:00 PM
Boostaholic's Avatar
All very viable options, but for 600hp a simple 402 iron block will do the trick, with pretty much any F/I you put on it.
Old Mar 23, 2005 | 01:06 PM
777's Avatar
777
that would be my route as well...except i think i'm going to hold out till the ls2 knock sensor problem is fixed...then get an aluminum 408...if i need it before then i'm going to get hpe's 408
Old Mar 23, 2005 | 01:34 PM
datsbad's Avatar
i already have the engine LS1 aluminum so what are my options ? 383 sounds good!
Old Mar 23, 2005 | 01:41 PM
777's Avatar
777
you can 383 stroker, 388 all-bore (re-sleeve), 427 stroker and all-bore combined...that is about the only options you have that i can think of...383 will be BY FAR the cheapest...and prolly your best bet
Old Mar 23, 2005 | 02:11 PM
datsbad's Avatar
could you provide me with someone products to look at ? 600hp should be easy with low boost with heads cam intake right!
Old Mar 23, 2005 | 03:18 PM
jrp's Avatar
jrp
SN95 Director
sell the ls1 and build up an ls2 402. by the time you do all the machine work, purchase the rotating assembly, ect the price difference between the 383 and 402 is minimalistic.
are you talking flywheel or rear wheel HP? with the proper h/c setup on the 402 you can have over 500rwhp easy.
Old Mar 23, 2005 | 06:45 PM
HUGGER ORANGE SS's Avatar
Hell.. 347ci Aluminum Block and 10 psi blower I'm over 600RWHP... Now pushing 14psi and I'm over 700RWHP..
Just add a blower..
Clint
Old Mar 23, 2005 | 06:47 PM
jrp's Avatar
jrp
SN95 Director
Just add a blower..
Clint
under the curve power > peak
Old Mar 23, 2005 | 09:43 PM
777's Avatar
777
track times > under curve power > peak power
Old Mar 24, 2005 | 09:57 AM
datsbad's Avatar
guys what would a escalade 6.0 short block do for me ? any options with that ?
Old Mar 26, 2005 | 12:49 AM
datsbad's Avatar
anyone ???
Old Mar 26, 2005 | 05:58 AM
ssheets's Avatar
What is the typical cost to resleeve an LS1 to a 427 (4.125???) bore?
Looking towards the future, something about a 427 badge on the side of an SS that just gives me wood
Old Mar 26, 2005 | 08:23 AM
777's Avatar
777
a 427 will run you near 18k depending on wherever you get it from...they aren't cheap...to be honest they aren't worth it...especially since you can get a 408 for about 5k
