gtp heads milled question
Old Mar 23, 2005 | 03:21 PM
stockredta's Avatar
Default gtp heads milled question
how much are gtp stage 2 heads milled?
stage 2 heads and what is a big cam say on a 110 lsa i could run wiith these?
tia, mike
Old Mar 23, 2005 | 05:50 PM
VSGLS1's Avatar
Hmm...I think you can get them unmilled from them, unless you are getting someone who had them milled.. Also why are you set on a big cam with 110LSA? Need a little more info on the goal of the setup in order to comment.
Old Mar 23, 2005 | 06:01 PM
stockredta's Avatar
yes i want to go with a 232/232 on a 110lsa
Old Mar 24, 2005 | 08:42 AM
VSGLS1's Avatar
Lift? Stock pistons with no flycutting??? Need more info. Unmilled you should be able to run that cam if the lift isn't over .595 or so.
