224R cam...thinking of maybe 110LSA
Old Oct 19, 2005 | 03:19 PM
Ragtop 99's Avatar
Originally Posted by Sharpe
Thanks a lot for that info! I'm no cam expert, but I wish I could get it with the lesser lift. I want as much low end power as I can muster without going smaller than a 224/224.
If you want a 224 lobe, call Thunder and see if they can order you a cam with their lobes on a 110 LSA. The TR lobes are lower lift than the XE-R but it is a faster lobe than a Comp XE, so you'll have a little less overlap at .006 which should make for an easier tune.
How much overlap do you want to run? TR also has a 226 lobe (listed as a 227); You could do a TR 227/227 109 and run about the same overlap as the guys running 232/232 112 cams.
Old Oct 19, 2005 | 04:18 PM
dug's Avatar
dug
Originally Posted by Patrick G
Notice how quickly the curve DIES after 5900. The combination would have made more average power and torque with a 110 intake centerline instead of a 106 ICL. While the low end torque is robust, the intake valve closing point of 38 degrees ABDC is just way too early for best power production. Study the graph carefully and compare it to others. You'll see what I mean.
Its tough to say. Not many cam only cams make over 400rwhp. How much more power would be made with a 108 or 110 ICL?
I find this cam interesting. My cam is almost the exact opposite. More duration, less overlap, more lsa and higher icl. I think it would make 400rwhp with a lil more tuning, all the bolt on's, and open headers. I would rather have the 224 110 106 cam because of all the torque and similar hp at lower rpms.
How much does the 110lsa hurt drivability and mileage? Can the engine be lugged around at 1k rpms in 6th gear like my 230 114 cam? The numbers almost seem unreal. Maybe they are since open headers add about 15rwhp.
Old Oct 19, 2005 | 04:28 PM
Patrick G's Avatar
LS1 Tech Administrator
Before you get too impressed with the dyno, keep in mind it was running open headers with 36" extensions...just the thing for impressive torque production. Even with all that working for it, the power and torque die off fast...too fast...this is all a result of too early of an intake valve closing. For best power and torque, 346 LS1s seem to like an IVC of 44-46 degrees ABDC. This one is at 38.
Old Oct 19, 2005 | 06:36 PM
Sharpe's Avatar
Yeah, I really think I do want a 224 lobe. This will be my first cam (engine builder chose last one), so all of my knowledge comes from reading on here and on other websites, and from studying dyno graphs.
This will go in a street car that will see maybe one or two days at the track in it's life (Of course, it will see a lot of country road showdowns...). So, low-end, stoplight-to-stoplight, torq is of prime importance.
I still haven't grasped overlap quite yet, because I haven't studied it hard enoungh, to answer your question intelegently. I know the equasion to figure it, and I know it's of vital importance, but I just haven't taken the time to read a lot about it yet. I also haven't grasped the "ICL" at all, or what the +x number is after LSA.
No need to explain it to me (unless you have a hankering); the information is at my fingertips, I just have to take the time to read it.
This 224 110 LSA cam is interesting. I would love to see a low lift, fast raqmp version. You say TR takes custom requests? I'm not in the market until I SELL MY '94 Z28 (!!!), but all the money from that will go toward my '99.
And Pat G, you know a lot more about cams than me by a long shot, but I bet he wasn't looking for "best power and torque," but a mean street machine. I could be wrong. In the city, my car sees a lot of 1500-2000 RPM time. The TR 224 seems to make real good power in there, I'm just looking at options. I know that I don't want to go lower than a 224/224, though.
Old Oct 19, 2005 | 07:51 PM
nuzee's Avatar
IIRC, I installed my cam at 38 IVC. Based on track numbers, I think I lost some power up top vs. the stock cam. So, PatrickG's statements are inline with my experience. I maybe more conservative than most and think that a 41 IVC would be a perfect street cam number to shoot for. Ahh, gotta love bench racing!
Old Oct 19, 2005 | 08:48 PM
Sharpe's Avatar
That's an ouch. Did you post lower 1/4 mile ETs? MPH?
EDIT: Wait. You're talking about the cam in your sig, right? That's not a 224/224 110 LSA. Okay. Nevermind.
Old Oct 19, 2005 | 09:14 PM
nuzee's Avatar
Just for clarification, my cam improved my 1/8 mi by 3mph but by the 1/4 trap I only had a 1mph gain. It didn't carry the 3mph gain over into the 1/4 trap. That's why I say it lost power on top. I could be totally wrong in my assumption, but nobody could explain it better.
I added 1.85 rockers a few months after the cam & was able to see that 3mph gain in both the 1/8 & 1/4 traps. OK, I'm done with my blah, blah, blah...
