LS1 vs LS2
Old Mar 23, 2005 | 10:48 PM
landonew's Avatar
Default LS1 vs LS2
Am going to build a 408. Firstly, would there be any advantage in going with an LS2 instead of an LS1? Also, is there an iron block ls2 out yet? I want to do a fairly substantial N20 direct port setup, 300, and i think iron is the way to go. Thanks!
Old Mar 23, 2005 | 11:04 PM
goober35's Avatar
If you want to be safe then i would look into the LQ4 or LQ9 block. They are the same block only diffrace is the pistons and u will be changing them.
If you use a ls1 block u will have to resleave the block and that will cost an arm and a leg and maby your first born.
Old Mar 23, 2005 | 11:05 PM
goober35's Avatar
P.S. the LQ4/9 is iron. Do a search on 408
Old Mar 26, 2005 | 02:09 PM
prostock_bigblock's Avatar
Go and look on the slp`s 408ci 6 liter iron short block , even though , there prices looks fair to me . and u have the option of low and high compression.
