Cam Specs
Old Mar 24, 2005 | 01:23 PM
Wicked 1's Avatar
Default Cam Specs
I need my cam spec
ls1 3714R/3716R/HR14+4
thanks
Old Mar 24, 2005 | 01:39 PM
gator's 99TA's Avatar
you probably want to give more information that that my man. what grind is that? comp XE-R grind? dont you have your cam card? look at your sig :p
Old Mar 24, 2005 | 02:07 PM
Wicked 1's Avatar
he said that he lost the cam card it not my car. I think that its a comp cam
Old Mar 24, 2005 | 02:17 PM
jpolser's Avatar
Just call up comp cams and give them those numbers. The first two are grind numbers. One for the intake and one for exhaust. They can tell you in a matter of seconds.
Jeff
Old Mar 24, 2005 | 02:19 PM
Wicked 1's Avatar
thanks
Old Mar 24, 2005 | 02:20 PM
jpolser's Avatar
The 3714 is a 222 with .566 lift
You'd have to call for the rest.
Old Mar 24, 2005 | 03:15 PM
Unaffliated Racing's Avatar
222/226 .566"/.569" 114LSA with 4 degrees of advance ground in.
Comp Cam..xtreme RPM high lift stuff...not XER
If you had a serial number ,I can tell you everything.....
