Will G5x2 Fit ?????/ Help!!
Old Mar 30, 2005 | 11:06 AM
JayplaySS's Avatar
Moderator
Default Will G5x2 Fit ?????/ Help!!
Some of you guys are smarter than sh@t when it comes to application! HELP. I have the Patriot LS6 heads 59cc unmilled stock deck height BUT with the 2.05 valve.
CAN I run the G5x2 with out a relationship between the valves and pistons forming!!
A S A P Please! Ordering today!! Anyone want my 226/585 cheap??
Old Mar 30, 2005 | 12:35 PM
JayplaySS's Avatar
Moderator
Help me please smartypants!!!
Old Mar 30, 2005 | 01:43 PM
Jimmy P's Avatar
You should be able to. You can even get a G5X3 on a 114 with those heads. I am going with the G5X2 on my Absolute Heads that have been slightly milled (5 thousenths).
BTW, did you notice that Speed Inc has a copy of the G5X2. Its called S16 on their website. They sell it for $379, compared to $450 plus $30 shipping from LG. I still got mine from LG though..
Old Mar 30, 2005 | 04:03 PM
JayplaySS's Avatar
Moderator
Thanks buddy! Anyone else. Gunnar said he knows some are running it and LG said I WILL need to cut em but they seemed confused that the Patriot heads have weld in 59cc chambers at stock deck height!! H E L P !!
Old Mar 30, 2005 | 04:08 PM
Louis's Avatar
Hunh. Nice to know about Speed Inc.
It will fit as long as you have stock thickness head gaskets.
If the heads are on the car, pull the 1# intake spring, and put that piston at TDC. Tell me how much the valve "drops" before it hits the piston. This measurement, between 180thou, and 220 thou will tell me if you have adequate clearance to be sure.
Old Mar 31, 2005 | 08:45 AM
JayplaySS's Avatar
Moderator
Louis you were recomended by LG to ask. I will check that today I guess and get back with a post. Thank you very much!
