Motor build up questions?
You should be able to do the stock crank, forged rods/pistons route and come in under budget and be plenty strong. You will need a low compression piston and get your heads done with bigger CC's. It would probably be easier to get a set of 6.0L heads done and match them up with a rotating assy to get your desired CR. Definatly spend some time in the FI section.
