Comp 918 Spring Poll
Old Dec 27, 2002 | 12:25 AM
James1's Avatar
Default Re: Comp 918 Spring Poll
So should I get with the REV Dual Springs or the Comp 918s with the T1 cam? (.559 lift)
<small>[ December 26, 2002, 01:53 PM: Message edited by: James1 ]</small>
Old Dec 27, 2002 | 12:34 AM
Slowhawk's Avatar
LS1Tech Sponsor
The way I see it any spring can break <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I've run 918's without problems,even the bad batch.I do not put too many miles on my car,but I do hammer it everytime I'm out.A big thing to do is make sure the engine is fully warmed up(oil) before revving it up high.A cold spring could break very fast. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 27, 2002 | 12:39 AM
T/A Medic's Avatar
I have about 2000 mi on mine with a CompCam 224 .581 112 cam... On motor and squeeze all is good. 11.745 and 10.735 1/4s
Thanks Much!
Old Dec 27, 2002 | 11:28 AM
Bad1le's Avatar
I just broke a 918 under normal driving. 2-2500rpm <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> I shift the car at 6400 when I run it hard. Spring broke in 2 places. Lift is .584 on the cam. No stripe on the spring that I can see.
AJ
Old Dec 27, 2002 | 11:40 PM
Paul J.'s Avatar
Over revving may have caused additional harmonics in the spring which may have led to the failure; hard to say. To measure the installed height, it requires the spring to be removed. The retainer is then re-installed and the space occupied by the spring is measured with a telescoping gage, and read by a micrometer. There are also micrometer style gages that fit within the spring pocket. Just adjust them out until no more space exists, then read the installed height on the micrometer dial.
Paul J.
Old Dec 28, 2002 | 12:53 AM
LS1x2's Avatar
Formerly 4mulaJoe
I could check the spring height. I'll probably buy the tool if it's cheap and I can find it. What's it called and where can I get it?
All of these springs have less than $1k miles on them. I have a TH350 with no speedo hook-up so I don't know the mileage. I actually think it's about 500 miles.
Am I just crazy to rev it all the way to 6800? Is that more than the 918's are rated for? It's seen 7k by accident(rev limiter) before as well.
<small>[ December 27, 2002, 01:07 PM: Message edited by: 4mulaJoe ]</small>
Old Dec 28, 2002 | 06:56 AM
thxone's Avatar
Blue stripe 918's and about 2200 hard miles and 8 1/4 mile passes and no problems.
Old Dec 28, 2002 | 10:03 AM
Plum Crazy Rob's Avatar
3200 miles, about 60 1/4 mile passes on
non-blue stripes with Comp XE-R 224 / .581....
Old Dec 29, 2002 | 10:48 PM
MelloYellow's Avatar
I've got 10k miles on a set of the 1st batches of CC918's. I think the 1st batch or two were ok. Pre-Blue Stripe.
Old Jan 3, 2003 | 09:28 AM
Firehawk 01's Avatar
As luck would have it I also had a 918 comp spring break on Wednesday, cam is a tr224. It did drop the valve into the cylinder, unfortunately this is as far as my mechanical ability goes so it will have to go to the repair shop. Spoke to Speedtek in Dallas and they will warranty the springs however the rest will have to come from my pocket. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> My car dynoed at 385 hp 377 tq on bottle it did 518 hp and 577 tq car had 4.10's at the time and now I am running the stock 3.42's
Old Jan 3, 2003 | 02:19 PM
James1's Avatar
XE-R 224? Does yours have .561/.561 lift or .578/.578 lift? Also, at what RPM did your spring break?
Old Jan 3, 2003 | 02:55 PM
  #32
Constrictor 98TA's Avatar
This may be a novice question, but how do you know when you break a spring? Does the car exhibit different behavior if you break an exhaust valve spring or an intake valve spring? What are the symptoms?
Old Jan 3, 2003 | 03:23 PM
  #33
LS1x2's Avatar
Formerly 4mulaJoe
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Constrictor 98TA:
<strong> This may be a novice question, but how do you know when you break a spring? Does the car exhibit different behavior if you break an exhaust valve spring or an intake valve spring? What are the symptoms? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can pretty much tell not all 8 cylinders are firing right.
Old Jan 3, 2003 | 03:50 PM
  #34
I8COBRA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Firehawk 01:
<strong> As luck would have it I also had a 918 comp spring break on Wednesday, cam is a tr224. It did drop the valve into the cylinder, unfortunately this is as far as my mechanical ability goes so it will have to go to the repair shop. Spoke to Speedtek in Dallas and they will warranty the springs however the rest will have to come from my pocket. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> My car dynoed at 385 hp 377 tq on bottle it did 518 hp and 577 tq car had 4.10's at the time and now I am running the stock 3.42's </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Which batch was this? When did you purchase yours? Were you spraying at the time it broke?
Just curious cause I'm throwing in a set of 918's next week.
Old Jan 4, 2003 | 06:39 PM
  #35
Louis's Avatar
I had one from May of 2002 fatigue on me~ 8kmiles.
I have run the Car hard, and shift ~ 6800, limiter is @ 7200. Plus, its a big cam.
IT didnt actually break, but it became weak enough to let one valve get tagged. After inspection, the spring is ~ 200 thou smaller top-bottom than all other 15. It happens. And Its going to happen again. Its just something that we have to take into consideration with our hotrods.
I broke 2 941s previously, and Im sure that Ill break more. Big cams, high RPMs, and lots of miles take their toll on springs.
Im now going to a REV double <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Take care
Louis
Old Jan 4, 2003 | 09:00 PM
  #36
I8COBRA's Avatar
I also scratched the 918 plan. My head machine shop also recommended the REV dual and I'm going with those, at least I wont drop a valve if one of those breaks.
Old Jan 4, 2003 | 09:31 PM
  #37
LOnSLO's Avatar
Running the 918's with the F1 cam at .591 lift. No probs so far running it up to 6800.
Old Jan 5, 2003 | 07:02 AM
  #38
LS1derfull's Avatar
I run #918 with .585" cam to 6500 rpm many times.I drive car daily, springs have over
13,000 miles and several backshifts with no valve control loss issues! Im still a fan of these springs.
Old Jan 5, 2003 | 09:17 AM
  #39
Paul J.'s Avatar
Wow, keep the reply's coming. I will be beginning my 918 experience today with a set of ported LS6 heads and Comp 220 .564 lift cam. They are the latest "Blue Stripe" variation. I will keep everyone posted.
Paul J.
Old Jan 5, 2003 | 07:40 PM
  #40
mike c.'s Avatar
where is this stripe your talking about? i have my r.g.r st2 heads off and don't see any stripe anywhere.
