heads
Old Apr 3, 2005 | 01:38 PM
treydeez's Avatar
Default heads
i have a 2002 camaro z28 and i would like to get a set of cyllinder heads to go along with the cam that i'll be purchasing which will prolbably be the tr224 with an lsa of 114 i have a goal of 400 horsepower to the wheels so what kind of heads should i be looking at i'm a little new to engine modification so any help is welcome and any suggestions would be great thanks.
Old Apr 3, 2005 | 01:42 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We have Precision Race Components 5.3l Stage 2.5 & Stage 1.5 heads in stock currently. You might check out some of the dyno results & track results in the other sections of the site. The heads feature new GM cores, new valves, gold spring kit with retainers all fully assembled!
You can get the stg 2.5 heads with camshaft & pushrods for $1999, or heads only for $1529
We also offer the stage 1.5 heads/cam package with camshaft & pushrods for $1899
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 3, 2005 | 01:48 PM
treydeez's Avatar
is there any way that you might be able to describe how the heads increase my horsepower? and what are the differences between stage 1.5 and stage 2.5
JMBLOWNWS6's Avatar
My TR224 cam on a 114 did 403 to the wheels. These guys cams are awesome New setup in the works.
Old Apr 3, 2005 | 01:51 PM
treydeez's Avatar
where did you get your setup from and who did your install?
Old Apr 3, 2005 | 01:56 PM
Y2KSS's Avatar
I received my PRC 5.3L stage 2.5 heads friday from Jason at TSP and they look real good. I'm using the G5X3 114 cam and hope this setup is better than the setup in my sig.
