looking for CAM input, thanks JRP for your words of knowledge
Old Apr 9, 2005 | 03:06 AM
ultraz's Avatar
Default looking for CAM input, thanks JRP for your words of knowledge
ok to start off, the car is a 98z28 with an A4 with 3:23 gears. Car has Pacesetter LT's, ORYP, Lid, ported maf ends.
Im looking for a cam that will see little drag strip use, car is my daily driver. im also looking to get a stall convertor, so that will play a factor in cam choice. Someone I spoke to said a comp cams 226 would be a great cam for me. The stall im looking to get will be from 2600-3600, im not sure. Im looking at replacing pushrods, springs, buying an ls6 intake manifold and getting a double roller. The only other thing is i MUST pass smog in CA. I WILL NOT be changing the gears. MY goal is the most performance and hp out of the cam and still pass SMOG. I will be swapping the LT's for stock manifolds at time of Smog.
any input on CAM and stall will be greatly appreciated.
Old Apr 9, 2005 | 03:41 AM
luv2spd's Avatar
The good ol tr224 would be perfect imo. I think its capable of passing smog.
Old Apr 9, 2005 | 09:37 AM
SiRgReg23's Avatar
Temple, TX Resident
ok dont make fun of me for asking but the tr224 would be the thunder racing 224 right ??
Old Apr 9, 2005 | 09:41 AM
Turo's Avatar
Yes.
Old Apr 9, 2005 | 09:42 AM
bmfcamaro's Avatar
yes. its an awsome cam.
Old Apr 9, 2005 | 01:34 PM
jrp's Avatar
jrp
SN95 Director
ya, the tried and true tr224 114 cam would be the perfect choice. you can try a few larger grinds but still keep the overlap in check.
