Ideal crankcase vacuum
Old Apr 10, 2005 | 11:36 PM
QuickSilver2002's Avatar
Default Ideal crankcase vacuum
What would be the ideal crankcase vacuum if you had some ability to regulate it with a vacuum pump…
I’m just trying to understand when you run into too much of a good thing.
Also, has anyone here tried the technique of maintaning a vacuum on the crankcase with a storage tank. I've seen it done before with a large PVC canister and a check valve.
Old Apr 11, 2005 | 12:02 AM
strokedls1's Avatar
Too much vacuum can suck the oil out the valve cover. I know of a car that had that problem and blew an engine or two. We just did a vacuum system today with air pump set up in reverse. I would not try this on a street car, but we will see how it works at the track. A couple of my buddies did this on there sixties drag cars with ls1 air pumps. I will try a pump vs. breather test in the next week or to when we get to the track.
Old Apr 11, 2005 | 03:51 AM
MelloYellow's Avatar
Consider an exhaust evac setup also if you want non-intake vacuum.
Old Apr 11, 2005 | 01:02 PM
strokedls1's Avatar
How do you go about doing that?
