Need help calculating CR.
Old Apr 14, 2005 | 01:22 AM
Alias's Avatar
Default Need help calculating CR.
Here is the setup.
6.0 Iron Block 408
Stroke: 4.00
Bore: 4.030
Piston Dish: -23.6cc
Head CC: 72cc
GM 6.0 MLS head gasket crushed thickness: ?
I need some help figureing this out. I did a search and read some of the threads but could not figure out exactly what to do. If there is any other info. needed to calculate this please ask and I will post it up.
Also I need the part number for the GM MLS 6.0 head gasket. I did a search and the part #12569365 came up but it is not a good number according to GM Parts Direct.
TIA
Old Apr 14, 2005 | 09:53 AM
smokemup's Avatar
Bore 4.03 (inches)
Stroke 4.0 (inches)
Rod Length 6.098 (inches)
Cyl. Head Vol. 72 (cc)
Deck Height -0.008 (inches)
Head Gasket Bore 4.1 (inches)
Head Gasket Thickness 0.055 (inches)
Piston to Cyl. Wall Clearance 0.003 (inches)
Top Ring Land Height 0.2 (inches)
Piston Dome Vol. -23.6 (cc)
Compression Ratio:
8.899 : 1
CR calc, Try it for yourself.
Old Apr 14, 2005 | 11:43 AM
Alias's Avatar
That is a great calculator. I will be keeping that and thanks.
Old Apr 14, 2005 | 12:27 PM
smokemup's Avatar
You're welcome.
Don't forget to check out the Dynamic Compression Ratio, DCR calc.
