G5x3?
Old Apr 19, 2005 | 05:38 PM
Solobarictahoe's Avatar
Default G5x3?
what is the difference between 112 lsa and 114 lsa is there a sound difference, idle difference, or a power difference between the two. i guess i am just wounders what a higher or lower lsa does thanks for the help
Old Apr 19, 2005 | 06:10 PM
98Grnz28's Avatar
112 lopes a little harder
Old Apr 19, 2005 | 06:13 PM
does eather or make more power?
Old Apr 19, 2005 | 06:32 PM
Orange Peel's Avatar
You will notice the 112 come on earlier in the power band, the 114 will peak a little later in the rpm range. Both will run well, the 112 would be a better choice if you want less clearance than the 114. If you want to play it as safe as you can, 114 is the way to go. I ran the 114 and loved it, I run the X4 now and love it even more. And the 112 will lope more, but the 114 still lopes NICELY!
