10w30 and ticking?
Old Apr 22, 2005 | 01:17 AM
00 Z71 Sierra's Avatar
Default 10w30 and ticking?
since i have got my truck i have used mobil 1 10w30 and a pf59 filter every 3 thousand miles, i also add some BG MOA oil additive http://www.bgprod.com/bgprofessional...s/autooil.html
it has kept csk down and keeps the motor quiet
today i changed the oil but didnt add the bg moa oil additive and now csk is worse and i can hear a faint knocking or ticking sound when driving by somethin so the sound is amplified back
was the oil additive just increasing the viscoity so it hid engine noise?
if it was, is there somethin i can do to quiet the motor back down without going with a higher viscosity oil or using the additive again?
Old Apr 22, 2005 | 01:42 AM
itchygomey98's Avatar
Imagine that, an LS1 that ticks. Do you have an exhaust leak?
Old Apr 22, 2005 | 08:56 AM
nope, im pretty sure its not an exhaust leak since i started hearing the noise after my oil change
this is happening in my truck with the 5.3, which is still part of the ls1 family correct?!?!
today at the shop im goin to poke around and see if i cant find out where the sound is comin from
Old Apr 22, 2005 | 10:32 AM
TNTramair's Avatar
y not try adding in that additive again and see what happens...if it quiets down then you have your answer.
I know that when i run 5w30 mobil 1 in the thing its louder than when i up it to 10w30 so im just gonna stick with 10w30 from now on.
Old Apr 22, 2005 | 10:38 AM
On the way to school i threw a code and had it checked out at autozone. They said it was the knock sensor...i guess i will be checkin that out at votech
Old Apr 22, 2005 | 05:58 PM
well we cleared out the code at votech and on the way back home it came back up..i guess this means the knock sensor isnt workin
Old Apr 22, 2005 | 06:51 PM
ss rally red's Avatar
I use Mobil 0W40 synthetic with great results, in all practical purposes it is really on the "thick" side of a 30 weight oil,Mobil syn has any/all additives that your truck needs,for myself I wouldn't throw off that chemical balance with the addition of an additive. As far as your knock sensor code there is a specific diagnostic flow chart to follow to see if the actuall sensor needs to be replaced.
