Questions about timng chain
Old Apr 23, 2005 | 07:08 PM
Hunter's Avatar
Default Questions about timng chain
I tried installing a comp cams 3153KT timing set today and the cran sprocket when its fully intalled barely engages the key. maybe only 1/8" or so. This is a 2 peice setup with the sprocket and the oil pump drive seperate. Can I use my stock crank sprocket?
