Dry sump oiling
The Armstrong pan with a Daily 2 stage scavenge is the least expensive with good durability on the street and track.
The pump installs on the block low on pass side. It takes up the space where the ac pump is from the factory, so the ac needs to go. We have a ATI hub that has a gilmer gear cut in the hub to drive the pump. If you look at our website you will see the basic parts needed.
Kurt
