Fly Cut??
Old Apr 25, 2005 | 11:30 AM
Blk98Z28's Avatar
Default Fly Cut??
How large of a cam would make fly cutting the piston necessary???
Old Apr 25, 2005 | 11:38 AM
xfactor_pitbulls's Avatar
Lots of info available, just use the search function. Somewhere in the 234/238 .600/.600 range you should start checking exact clearance and asking the manufacturer what they say the PTVC should be. That is for stock valves and unmilled heads.
Brandon
Old Apr 25, 2005 | 12:02 PM
bmfcamaro's Avatar
milled heads or stage 2 heads will make you have to flycut sooner.
