Compression and oil PSI
Old Apr 27, 2005 | 08:28 PM
ta981's Avatar
Question Compression and oil PSI
If an LS1 would lose compression, what happens to the oil pressure?
I was told that the oil pressure can drop. Is that true?
Old Apr 27, 2005 | 08:56 PM
TS6's Avatar
TS6
The 2 are unrelated, unless rpm's drop when you lose compression, which would cause lower oil psi, but they are 2 separate things.
