4.030 head gasket question
Old Apr 29, 2005 | 08:37 AM
Derek98z's Avatar
Default 4.030 head gasket question
I've a 6.0 liter block bored .030. Does any vendor make a head gasket for this exact bore? If not, I assume I should go with a larger bore gasket, correct?
Old Apr 29, 2005 | 08:53 AM
Richard@WCCH's Avatar
Cometic and SCE can make gaskets for your bore size in a variety of thickness. You shouldn't have a problem using the factory mls or Fel Pro gaskets either.
Good luck,
Richard
Old Apr 29, 2005 | 10:46 AM
ArcticZ28's Avatar
Yes, u're gonna wanna go a bit over your bore size. Cometic and FelPro have whatever you will need.
