Can I only use 1 O2 Sim?
Old Apr 29, 2005 | 01:13 PM
InfiniteReality's Avatar
Default Can I only use 1 O2 Sim?
Just curious as my little bro gave me one. Didnt know if I could splice off it, or I had to buy a second one. I have an ORY and I'm so tired of the SES being one.
Old Apr 29, 2005 | 02:04 PM
GuitsBoy's Avatar
I dont believe that you can. I think youll need to buy a second one.
Old Apr 29, 2005 | 02:13 PM
jmm98LS1's Avatar
Old Apr 29, 2005 | 02:54 PM
Well, it's worth a shot. It's from a 98 Grand Prix GTP. It's a 4-wire O2, but wonder if it's the same since it's a SC v6?
Old Apr 29, 2005 | 07:00 PM
Dan_the_C5_Man's Avatar
In general, you can use a single sim (specifics of your motor not withstanding..).
There is a site on the net that sells them; they go into detail about how it's one set of components w/ two wiring harnesses attached.
Old Apr 29, 2005 | 07:13 PM
GuitsBoy's Avatar
Interesting, but is it one component with two distinct channels? Reason being, is that i think youll have incorrect resistance if you have both sensors voltage go to one sim. Much like wiring a subwoofer in "bridged" mode on a 2 channel amp, each channel will only see half the load, thus putting out more than the sum of the two channels seperately. If these o2 sims fluctuate their voltage centered on .450 V, with half the resistance, would this now mean that they would fluctuate centered on .900 V? I dont know enough about electronics in general let alone the specifics of how an o2 sim works, but it does seem like it could create a problem...
...Or you could just try it and let us all know!
Old Apr 29, 2005 | 07:48 PM
bigdsz's Avatar
LS1 edit can delete the rear 02 sensors.
