6.0 bore ?
.030 over is no problem, on some 6.0L blocks you can do .060 over but you need to sonic check the block to make sure .060 is safe.
if you go .030 over with the stock stroke you get a 370ci setup
on a .060 bore and stock stroke it would be a 375ci setup
Yep, stock stroke. Can't tell you how it runs yet as I just swapped it in yesterday. I still have to put the heads and accessories on. I'm sure I'll be posting a vid once I do get it up and running though
Originally Posted by BLWN1
Whats going rate on a block or complete motor?
Awsome...keep us posted.
FYI, simple CI calculator
((Bore)\2)^2*(3.14)*stroke=displacement
derived from
Area of circle = pi(r)^2 where pi~3.14
volume of cylinder = Area_circle * length
bore = diameter = 2*r
Hope that helps future "ci" questions
derived from
Originally Posted by sb427f-car
You on stock stroke then? How's that sucker rev with the extra bore?
the iron blocks are great for FI or juice applications due to the extra strength.
we did a 6.0L ironblock 370ci setup with N2O heads and cam that made 463rwhp and 430rwtq N/A, so it should run very well
I agree.
Plus if you have it 30 over and something minor happens you can always bore it a little more.
Yeah, I know. And a much cheaper alternative to get some strength and some extra cubes.
Originally Posted by JZ'sTA
I agree.
Here is a copy oy my last blocks sonic test. I offset the bores to get maximum wall thickness. Thrust sides are all pretty thick, but the pin side on the inner pistons is where it can get thin.
