Losing Coolant
So I am guessing cracked block?
That sucks Ed. At least it will hopefully stay together until you're ready.
See you tomorrow to start tearing mine apart ! I'll give you a call when I'm on my way, probably around 4:30 or so.
When you shop around make sure you talk to the guys at LME, and to Steve @ Race Engine Development (father of the MID sleeve). Steve is local to us in Oceanside :
Steve Demirjian
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
Rob (Bad30th)
Went to tighten it, of course broke off the bolt.
Any idea of a easy way to get it out?
Well, at least you found the leak... That's good news.
EZ-out ? Crow's foot maybe ? If the head broke off hopefully the broken piece is not under pressure anymore and will be easy to get out - but sheesh, thermo housing, what an inconvenient place to get to to work on it...
Lemme know if you need a hand...
BTW, got on it some yesterday PM and this morning. Making about 2-3# with the cutout open and about 4# with it closed. Feels fine ! Can't wait for new pulleys and more boost. One thing I've noticed is I need to tune the low end VE back up because it's stumbling a little down low now, especially when warm. The bigger chambers need a little more air I think (closer to the stock table).
Rob (Bad30th)
Might be a good time to take the plunge since you don't need a new block.
Rob (Bad30th)
Rob (Bad30th)
You havn't heard the lastest have you...
https://ls1tech.com/forums/generation-iii-external-engine/323498-broken-starter-mount.html
Damn bro, no good luck for you this week I guess... Are you gonna try to fix the starter bolt tab on the block or just start looking for a new setup ?
How bad is the break ?
That sucks !
Rob (Bad30th)
