TR 230/224 Cam.....
Sorry for all the questions.
Andy
The idle and driveability is not bad at all once you get the TB hold drilled out some. After you do this, you should be fine.
I used 918s w/ this cam and had zero issues.
Jason
I am somewhat worried about spinning my motor to 67-6800 all the time. I was hoping I could shift at 65-66. my limiter is set to 6800 and I am also running a stock bottom end. I just don't have the back up cash to snap a rod bolt or two.
The dyno sheet that TR posted shows that the cam hits peak right about 5900-6000. That should be fine for me to shift at 6500. At least I hope so.
Andy
