Springs Comp or Crane?
Old May 2, 2005 | 12:29 AM
sandking's Avatar
Default Springs Comp or Crane?
Is Comp worth the $175.00 extra over the Crane, or is this just another "waste of money" product?
Old May 2, 2005 | 12:33 AM
TNormZ28's Avatar
Comp 918's unless you need duals then go with the Cranes. I hear a lot of good things about Patriots dual springs but have only had experience with the Crane duals.
Old May 2, 2005 | 12:34 AM
sandking's Avatar
They are duals- Crane Cams 144832 or Comp 26921
Old May 2, 2005 | 12:37 AM
TNormZ28's Avatar
Then Crane or Patriots.
Old May 2, 2005 | 12:59 AM
TVWilkes's Avatar
I recommend the PRC spring kit.
Old May 2, 2005 | 01:01 AM
jrp's Avatar
jrp
SN95 Director
if its the X4 your looking at i'd opt for the 921's over the cranes. if you run the cranes you'll need to shim .030 (i believe) to get adequate seat pressure.
Old May 2, 2005 | 06:53 AM
XTrooper's Avatar
The Crane valve springs are great and they cured the harmonics problem I was having with a set of PRC duals. However, I am using .060" shims with them as recommended to me by Crane.
