Symptoms of internal engine damage?
Old May 2, 2005 | 12:35 PM
2000Blackout's Avatar
14 degrees? Damn that is killing you right there!
Old May 2, 2005 | 01:09 PM
zamboxl's Avatar
Originally Posted by nikkev
Well, honestly I had forgotten about it It was when I was having lots of misfire issues. I changed out my wires and the misfires went away. I totally forgot about the knock retard as I assumed it was related to the misfires. And I didn't think you had that parameter running the other night?
boo this man boo this man folks lol just kiding yea get your self some new ones you'll see that beast come alive again. now if my problem was onyl that simple .
Old May 2, 2005 | 01:55 PM
ArcticZ28's Avatar
I e-mailed Jeff to see if my knock sensors were turned off (although I don't know why they would be) and I will run A-tap on the car again today to make sure I still have the knock retard. Can I tell if the sensors are bad by just pulling the intake? Will they be good if they look good? I don't want to just throw parts at this car anymore, i want it to run again!
Once you take the intake off you just pull the big round plugs off the top of the valley cover and pinch (you'll see what I mean when you get in there) the attached wires off of the sensors. Then you just unscrew them. I doubt you'll be able to tell anything from just looking at them... unless both are completely missing
Old May 2, 2005 | 02:27 PM
1999T/A's Avatar
The knock sensors are supposed to read a certain ohm value . Anybody with a GM manual handy wanna chime in and let him know what that is ? Im at work or else I would look it up in mine . ..
Old May 4, 2005 | 11:29 AM
nikkev's Avatar
Well, knock retard is now showing 0 and the car drives great. Still waiting for a compression guage to test the cylinders. Other than that.....
Old May 4, 2005 | 12:10 PM
MrDude_1's Avatar
you change the knock sensors?
Old May 4, 2005 | 01:08 PM
nikkev's Avatar
No, just re-scanned the car with the new plugs/wires and better gas....
