should i be worried?
Old May 2, 2005 | 02:32 PM
ty_ty13's Avatar
7 Second Club
Default should i be worried?
I left the stock timing chain on when i did my cam swap. car has 24,xxx miles
Old May 2, 2005 | 02:41 PM
777's Avatar
777
probably not...but i would've changed it...the stock chain was run on my car for prolly 5,000 miles and it had 95,000miles on it...although it did have quite a bit of slack in it when i changed the oil pump and replaced it with a rollmaster double roller...i have a m6 as well and they are harder on the timing chains...
Old May 2, 2005 | 02:59 PM
blkZ28spt's Avatar
You should be fine. It is not required, only recommended. How high do you rev? The higher you rev the more it is recommended that you get a new one.
Old May 2, 2005 | 03:08 PM
BBQLS1's Avatar
RECOMENDED not required.
