Lingenfelter GT2-3 Cam kit, What springs?
Can anybody confirm that the Lingenfelter GT2-3 cam and spring kit comes with Comp cams 915 springs? The box says 26915-16 on it, but not sure if they are repackaged or what.
When I bought my GT2-3 cam from them, they did not offer it as a kit. At that time, they recommended the 26-918's, which is what I went with. I don't know if that has changed since that time.
Originally Posted by Dan_the_C5_Man
Typically they ship stock LS6 springs w/ that cam..
Yes they fit both.
The 915's are kinda like a LS6 02++ spring replacement. I would prefer 918's myself, but with that cam they will work well. Just make sure that they are installed correctly (correct height).
It is not that hard, stock rockers to be tightened to 22ftlbs (that is critical).
Get the best trq wrench you can afford.
Also if you change retainers so you should change locks (really cheap at GM)
This the comparison between the two in the middle of page. Just less load capabilities.
