Pics of my Bo White ported 241's
Old May 4, 2005 | 02:52 PM
  #61
Bo White's Avatar
I have seen on here were some guys are runnin cams simular to yours and have heads that are milled .050 so you should be ok but may want to double check. I have access to 5.3 cores if needed.
Old May 4, 2005 | 03:05 PM
  #62
josh99ta's Avatar
Sold The Fun Stuff :(
Originally Posted by Bo White
It will be close, whats the ICL?
Thanx cyphur
I'll find out and we'll mill them as much as we can and still maintain reasonably safe clearances.
Old May 4, 2005 | 03:10 PM
  #63
Redlinez's Avatar
How much for the 5.3 cores?
Old May 4, 2005 | 03:24 PM
  #64
Bo White's Avatar
Usually $200 on the 5.3s.
Old May 4, 2005 | 04:19 PM
  #65
cyphur's Avatar
can ya hook a fellow porter up w/some 243 castings for cheapish?
Old May 4, 2005 | 08:26 PM
  #66
JZ'sTA's Avatar
Damn thats pretty cheep for castings.
This guy seems to be the type of person I would want my daughter to date.
2 bad I dont have kids yet.
Old May 5, 2005 | 09:34 AM
  #67
Bo White's Avatar
Those castings are bare and will need valvetrain. Thanx for the complement...I think lol. I have been porting cylinder heads since '94 and have been enjoying it ever since. I started porting heads for myself since I couldnt afford "good" heads back then and grew from there. I try to market myself to guys like me that would have to port em theirselves but do not have the knowhow and/or equipment and nothing more. I really appreciate the props and comments and will always help people when I can since thats what its all about. Thanx for everything, ls1tech!
Old May 5, 2005 | 09:47 AM
  #68
josh99ta's Avatar
Bo, the ICL on that cam is 108 degrees. How much can the heads be milled and still maintain PVC on stock thickness gaskets using stock valves? How much can the heads be milled and still maintain PVC on stock thickness gaskets and 2.02 intake valves?
Old May 5, 2005 | 10:26 AM
  #69
Bo White's Avatar
I feel that a .558" 221 cam will clear fine with a stock valved, .050 milled head and .045" milled, 2.02 valved head.
Old May 5, 2005 | 10:29 AM
  #70
Cal's Avatar
Cal
Bo I see you becoming a very busy guy in the near future!
Old May 5, 2005 | 10:49 AM
  #71
Bo White's Avatar
Thanx Cal....Im already there
Old May 8, 2005 | 10:19 AM
  #72
Krab's Avatar
Hmmm, I might have just found my next mod.
Old May 8, 2005 | 03:23 PM
  #73
Bluehawk27's Avatar
Damnit, a couple of guys and I were about to pull our heads off and send them into Bo, and then i read the sticky at the top of the forum. Oh well, good luck in your new venture Bo.
Old May 8, 2005 | 04:44 PM
  #74
gaga's Avatar
I know!! This is like the most anticlimactic thread ever....
Old May 8, 2005 | 05:13 PM
  #75
Bo White's Avatar
Dont sweat it guys, Im just a novice at this stuff anyway. I do all of my porting on the talegate of my S10 and have never used a flow bench . Some of the locals know this. I just got word that my "new port" is actually smaller than the old one and pulls better numbers down low but takes away from the higher ranges. This is just what you run into trying to better yourself without the aid of a flowbench, well atleast the ports flow "carbon copies" of each other
Old May 8, 2005 | 10:36 PM
  #76
ninobrn99's Avatar
Hey gomer, where did you get the rev valves from?
Old May 9, 2005 | 09:09 AM
  #77
Bo White's Avatar
Hopefully we will get some power #s out of gomers car and evaluate were Im at and will be doing my older port for the heads I have to do until I can devote time on redoing my new port.
Old Nov 23, 2005 | 09:10 PM
  #78
JRracing's Avatar
Sweet bo, I have been contiplating taking my 241's off and getting a full blown port and valve job. Instead of putting these 5.3's on.
Old Nov 24, 2005 | 12:10 AM
  #79
JS's Avatar
JS
So lets see,If I send u a set of 241 castings and my 918's...U will port them,mill them,and do the valve job and install springs for 750?
Also what PR would I run and I was going to use a .051 MLS Gasket.
I wanted about a 62 to 64 CC chambers...
If I go 5.3 then I'd need to buy valves..I think the stock valves are more than adequate for my mild 214-222 559 566 115LSA Camshaft too.
Old Nov 24, 2005 | 12:44 AM
  #80
dudas35's Avatar
He doesn't do porting work anymore. He sends them off to be CNC'd since he is working full time now. I already tried.
