TEA Heads
Were they bought direct from TEA?
Have you called TEA?
What is the spark plug readings like from bank to bank?
A4 or M6?
Sounds like you may have a serious problem somewhere if it is a M6
What type of exhaust are you using . I have noticed you better have a great exhaust if you want to run a reverse split with good results.
Our heads have never worked very well with a reverse split cam but I would expect them to do better than that.. How old are the heads? Did you get them from us or from someone else?
What springs are you running?If it is the old comp 978 I think you are pressing it on the valve spring side.
What are your other mods?
I made well over 400 rwhp with a TR 224/224 at .561 on a 114 with LTs and the TEA 5.3 heads. BTW, I did have very close piston to valve clearance with this setup and that relatively mild cam.
Sounds like a careful install check and a leakdown test is in order. If all is well, get it tuned professionally.
Perry
I would check your valve springs first. Then do a leakdown test.
Send me a PM when you get a chance.
I am running TEA stage 1.5 heads with the mods in my sig. and I put down 365hp on a DynoJet. The 3450lb car runs low 11s all day long and a best in the high 10s and has trapped in the mid 124 range. Needless to say I do not believe my dyno numbers.
John
John
Who cars when it runs as well as your car?
My thoughts on this is someone did not install the heads you gave them if you prove to be a TEA customer.
