6l vs. ls1/ls6
Old May 4, 2005 | 04:20 PM
KAOS's Avatar
Default 6l vs. ls1/ls6
what is the difference between the 6l cranks and the ls1/ls6 crank? are the cubes made up with bore or is the stroke a little bigger in the the 6l. i there any difference in strength between the two? thanks in advance
Old May 5, 2005 | 09:19 PM
jrp's Avatar
jrp
SN95 Director
ls1, ls6, lq4, and lq9 all use the same 3.622 stroke. the displacement difference is in the bore; 4.00 vs 3.898.
6L has a solid center while the 5.7L is drilled
Old May 7, 2005 | 01:45 PM
KAOS's Avatar
so a ls1 crank is the same as the 6l. thats all i wanted to know
Old May 7, 2005 | 01:59 PM
Scalpel's Avatar
Same stroke but the 6.0L crank is stronger b/c it's solid and not drilled. But the 5.7L crank is lighter b/c it's drilled.
With F/I I'd use the 6.0L solid crank
Old May 7, 2005 | 04:51 PM
KAOS's Avatar
sounds like a plan
