Anyone ever heard of this for lifter cure?
Has anyone dealt with this stuff or is it a waste of money, if so, could you let me know what the outcome was? Also, can a collapsed or tuned lifter even be cured? Thanks.
Charlie
Think about this, you are thickening up your oil which means the rest of the motor is getting less oil, and the pump is having to work harder...
If you think you have a turned lifter, better tear down the engine ASAP before it takes out more than the lifter. It happened to me . . . and I designed a part to prevent it from happening again. Let me know if this turns out to be it, I can help.
MMO works great as an engine flush...but so does ATF/Dextron III, we do so many oil changes a year( my shop does 18K a year,yes 18k
) so many people come in with 15k-18K on their last oil change
you would not believe it
They come in with the oil light on/the lifters ticking(even cars with 15K on the original oil
) we in these cases recomend a flush to clean out the varnish but complete the service with pure oil, the way the manufacturer intended.
