CC216/220 cam card
Old May 6, 2005 | 07:43 AM
DJ_951's Avatar
Default CC216/220 cam card
Does anyone have the cam card for a Comp Cam part #54-414-11, 216/220 .525 532 114LSA
I purchased the cam used. Would like more info the base circle and stuff. Want to get the right length pushrods, thinking 7.425's. Nothing off the heads. If anyone has this cam let me know what you think. Have a M6 and will be installing ARE stage 1 heads. Don't have headers just a MAC y-pipe (no cats) going for a sleeper/tire burner daily driver. Don't drag race Thanks
I have the info off the site:
Camshaft Specification Table
Part Number 54-414-11
Engine 1997-1999 Chevrolet
350ci,
Generation III LS1,
8cyl.
Grind Number LS1 XR269HR-14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.525 0.532
Duration At 0.006 Tappet Lift 269 273
Valve Timing At 0.006
Open Close
Intake 23 66
Exhaust 73 20
These Specs Are For The Cam Installed At 112 Intake CL
Intake Exhaust
Duration At 0.05 216 220
Lobe Lift 0.309 0.313
Lobe Separation 114
Recommended Valve Springs 941-16
Old May 6, 2005 | 11:23 AM
DJ_951's Avatar
when you say 7.4" your talking a true 7.4" not stock 7.38"?
