Cam specs from reading the etching?
Old May 6, 2005 | 08:55 PM
DALLAS's Avatar
Default Cam specs from reading the etching?
I ordered a cam and I want to know if you can find out the specs from the number hand etched on the end of it. It reads this number: 267A.
Old May 6, 2005 | 09:02 PM
jrp's Avatar
jrp
SN95 Director
need more numbers. if its a comp grind you'll see 3728R/3730R HR114 for example.
and where did you order it from?
Old May 6, 2005 | 09:07 PM
DALLAS's Avatar
ordered it from smc performance. on another part of the cam it has stamped 323 and under it it says 98.
Old May 6, 2005 | 09:09 PM
DALLAS's Avatar
its supposed to be an asa cam. i was just seeing if you can tell from just the numbers that were on it.
Old May 6, 2005 | 09:11 PM
jrp's Avatar
jrp
SN95 Director
well if its a GM cam it should have the full part number you can look up.
Old May 6, 2005 | 09:31 PM
DALLAS's Avatar
i guess i should call and ask them then.
