truthful cam help
Old May 7, 2005 | 11:11 AM
zo02ss's Avatar
Default truthful cam help
I have a stock bottom end and am going to get afr 225's and am looking for a cam to max maximize my heads but be an excellent daily driver. I am also ording a 90/90 set up for this and will be spraying a 150 shot. 12 bolt with 4.10's and it is a m6. your help is very much needed. I also like rough idle.
Old May 7, 2005 | 01:09 PM
66deuce's Avatar
i would call Tony at AFR and ask him what he would recommend,i'm sure he knows better than anybody what would work with his heads.
Old May 7, 2005 | 01:13 PM
blkZ28spt's Avatar
Define excellent daily driver. Some people wouldn't go larger than 220 or 224 and consider it an excellent daily driver. I consider my cam excellent for a daily driver. You can't really MAXIMIZE the heads and be an excellent daily driver. Have to sacrafice one or the other to an extent.
Old May 7, 2005 | 02:08 PM
Cal's Avatar
Cal
Ditto this. I would go with the TSP MS3 a second time, although I really like my cam. Most of the cams sold by the sponsors are good in a daily driver, IMO. You would really have to special order some kind of a custom cam to get one that's too big.
Old May 7, 2005 | 02:54 PM
zo02ss's Avatar
I mean i want it to be very reliable. Like if i take a 200 mile trip i don't have to worry about springs. I really want to get a good set of springs and that be it. Never to have to worry about them again unless something just happens.
Old May 7, 2005 | 04:25 PM
blkZ28spt's Avatar
You can't install and forget about any performance spring. You will have to check the springs every so often even on the milder cams. Unless you get a hotcam, asa or LS6 cam (or something similer) with LS6 springs you will have to run stiffer aftermarket springs. Comp 918's are a VERY good spring, and there are multiple dual springs out there that perform very well as well.
Old May 7, 2005 | 08:31 PM
luv2spd's Avatar
Well, a 200 mile trip certainly shouldn't be a problem. Its recommended to check the springs every 15k or so depending on usage and of course which cam you have.
Old May 7, 2005 | 09:36 PM
Tech's Avatar
You are going to put huge heads on a car with a 'small' cam? Bigger isn't always better. Get the AFR 205s and put in the same cam (or similar) to the one Tony's running.
Old May 7, 2005 | 10:03 PM
Drew778's Avatar
I say AFR 225 and MS3, with 4:10 gear and a 150 shot you'll be flying
Old May 7, 2005 | 10:16 PM
luv2spd's Avatar
Yeah, I didn't even catch that. Why are you so set on the AFR 225's if you're wanting a smaller cam. If you get those heads I'd suggest getting a cam similar in size to the MS3 as suggested above. That would be a great combo.
Old May 7, 2005 | 11:27 PM
zo02ss's Avatar
I never said any thing about a small cam. If I am going to put a cam in my car I will put a big one with big heads. I like to leave myself with no room to go bigger. That is why I want the 225's. I was leaning towards lg x3 or x4, ttp equilizer or the f-15 ron jeremy. i just was asking which big cam is pretty easy on springs from those who have had experience with them.
Old May 7, 2005 | 11:32 PM
blkZ28spt's Avatar
We kinda thought small based on your "excellent drivability" clause. Leaving no room to go bigger on a cam isn't generally thought of as excellent drivability. MS3 is a nice cam.
Old May 8, 2005 | 10:35 AM
PREDATOR-Z's Avatar
Are the AFR 225 62cc out?? otherwise you would have top mill the 72 cc a good .036 just to get a 66cc chamber. That alone will eat a little flow.
More and you'll flycut on a huge cam.
G5X3 with 205's and flycut have been making some awsome power. I don't see the point of running a big H/C without at least 11.0:1 SCR and that requires flycutting.
