Over-filed rings.. :(
Old May 9, 2005 | 01:28 PM
Juiced LS1's Avatar
Default Over-filed rings.. :(
Went a little over on a 2 rings when filing. Does anyone know where I could purchase 2 Diamond 3.905" top rings?? Diamond says they won't do it, so I hope I'm not SOL here.
Old May 9, 2005 | 01:36 PM
LOnSLO's Avatar
How far over did you go?
Old May 9, 2005 | 01:50 PM
smask04C5's Avatar
if you went over a couple of thousandths, put it together
Old May 9, 2005 | 01:55 PM
TTPMatt's Avatar
I have a broken up set I would be willing to part out a few rings from. I'd be looking for $25 for the rings I can have them in a box today and out the door if ordered by 5pm EST.
- Matt
Old May 9, 2005 | 02:36 PM
BrentB@TEA's Avatar
- Matt
that sounds like a killer deal to me...if you only went over .001"to .002" I would not worry about it.
Old May 9, 2005 | 02:38 PM
TTPMatt's Avatar
A bit expensive but it sucks breaking up a set of $170 rings just to get 1 set for 1 piston and then having 7 left over.. That's why we have to make up some cost. But I do have them sitting here waiting to leave. As Brent said if its very close I wouldnt worry too much but depends on what you are setting the car up for n/a, fi, n2o.. N/A is a little more forgiving than any of the others obviously.
- Matt
Old May 9, 2005 | 02:41 PM
Juiced LS1's Avatar
- Matt
I'm only about .001-.002", maybe a little more over on the 2, but the ends are pretty choppy and uneven. Call me picky, but I'd like to redo. I'll give you a call, thanks..
Old May 9, 2005 | 04:20 PM
ROCNDAV's Avatar
Another thing you can do, is try that ring in another cyl bore. All bores should be the same, but just moving it to other bores, you might find that the feeler gauge is just a little tighter that the others in one or more cyl bores. if you have you old pistons, you can make a cool test tool by popping two used rings inthe groove of the piston, then put the new ring in the bore and push the piston down (upside down) into the bore until the rings hit. That way your rings are at the same height everytime. here's the best i could draw up in paint in 3 minutes
D
Attached Thumbnails Over-filed rings.. :(-piston-test-tool.jpg
