cleaning the inside of a LS1
Old May 9, 2005 | 08:41 PM
fattdaddyLS1's Avatar
Default cleaning the inside of a LS1
Doing a LS1 swap into a 3rd gen And I'm breaking the motor down to make sure ever thing OK. Inside the motor needs to be cleaned the motor ran great before I removed it but It had 100,000 miles on it and I would like for it to be cleaner before puttng it back together I heard about filling it with diesel fuel then spraying out the gunk with brake cleaner. Will this harm the motor and after I do this what would be my next step?
Old May 10, 2005 | 07:06 PM
Come on i need help!!!!!!!!
Old May 10, 2005 | 08:05 PM
stik6shift93's Avatar
if it isn't broke don't fix it, i would leave it alone
Old May 10, 2005 | 09:12 PM
don't want to fix it just want to clean it out to make sure that nothing will harm it when I fire it up!
Old May 10, 2005 | 09:32 PM
Cal's Avatar
Cal
Inside the motor as in crankcase? You shouldn't ever need to clean that unless something has been machined, they you run it through a parts washer to get the metal chips out. It would be more useful to clean the carbon out of the heads and off the piston tops.
Old May 10, 2005 | 09:56 PM
samgm2's Avatar
I would NOT use gunk. Especially the engine brightning variety. This will degrade the aluminum.
Brake cleaner would be fine. Avoid hitting rubber gaskets.
Sam.
Old May 10, 2005 | 11:15 PM
Grimes's Avatar
One more vote for "don't mess with it".
Old May 10, 2005 | 11:28 PM
Cal's Avatar
Cal
Rather than cleaning it, why don't you remove the oil pan and relplace the gasket. While you've got the oil pan off, remove each con rod cap and inspect the bearings. Of course you will need new rod bolts to put it back together, so get some ARP's or Katechs. On a motor with that many miles, I bet the rod bearings don't look that great. I was just checking mine and found one bad one; only 30,000 miles on the motor. It was a hellish 30,000 though!
Old May 11, 2005 | 11:31 AM
if you want to clean the inside of your motor, just replace one quart of oil with a quart of transmission fluid. May sound weird but transmission fluid has a lot more detergints in it than motor oil and won't hurt anything. If you like to keep your motor clean run synthetic too. I was amazed how much it helps, i pulled the valve covers off on my ta with 85k on it and the aluminum looks great, just like it would new. When we pulled the covers on my buddys motor with 62k on it(he doesn't run synthetic) the aluminum looked all brown and stained.
Old May 11, 2005 | 12:51 PM
luv2spd's Avatar
You're likely to loosen up crap that won't get cleaned out all the way.
Old May 11, 2005 | 05:30 PM
WHAT So after I do what I'm going to do whatever that may be what should I do to keep the motor in good condition while I what on parts!
Old May 11, 2005 | 05:54 PM
if the motor is going to be sitting for a while spray it down with some wd-40 to prevent corrision. It's not going to increase the longevity of the motor if you clean the pistons and internals off. The only thing that i'd really be worried about is build up in the oil passages and running the motor with a quart of atf in there will clean that up. If you're gonna take the motor apart you're also gonna need all new bolts as they're stretch to yield and can't be reused. If you want to do something worth while then replace the bearings in it and rehone the cylinder walls and put new rings in.
Old May 11, 2005 | 06:21 PM
conan's Avatar
I agree, all the time and effort spent in swaping a motor with 100k seems alittle crazy to me. You can have the crank polished and like said above rehone new bearings(cam,crank,rods) new rings, and internal balance for afew hundred dollars,and never have to worry about it again. Just my .02
Old May 11, 2005 | 09:02 PM
I got the Motor and tranny for an great deal and it ran great thats why I'm using it to do the swap, but replacing the bearings and rehoning ,ETC.. is what I planned on doing anyway just want to know the best way to clean the parts that I was not going to replace!
Old May 11, 2005 | 09:46 PM
conan's Avatar
If your taking the block to a machine shop they should have a hot tank, your block should look like new when you get back, The pistons you can use brake clean and a green scruby to get the carbon off, there is also a tool to clean out in between the ring lands. Are you reusing the heads?
Old May 12, 2005 | 03:33 PM
~JOSHUA's Avatar
I wouldn't take it down to the bare block, but with that many miles it most likely is a pre 2001 engine. I'd change the oil pump NOW! Might as well do the rod bolts, timing chain, a bigger cam and springs. Better pushrods too. When you bolt it together an ASP pulley is $ well spent.
You can run those engines hard for 160k + miles without much of a drop in power.
Old May 12, 2005 | 03:59 PM
WedWoseZ's Avatar
I agree with conan. A reputable machine shop will make sure the block is next to pristine (I assume that is where you are seeing most of the "gunk"). That is assuming you are taking it down that far. If so, then definitely do the bearings. It can't hurt, and if you trust your own work enough, it is added security.
One more thing before I go seriously think about all the future mods you plan to do. If you can afford them now, DO IT! It will be much easier, especially while the engine is not in the car!!! Plugs, Oil Pump, Timing set, Cam, heads, blah, blah, blah (it is the same old rhetoric you will get/have gotten form everyone else!
Just remember what ever you do, have fun doing it! Enjoy.
Old May 12, 2005 | 08:47 PM
Thanks for all the replys I have decided to do as stated and just do all my mods a once (heads,cam,etc) and have it all put together by the same shop at the same time as the lower end is being done. I will be replacing the oil pump and chain and I'm not going to reuse the heads. Now all I have to do is figure out what heads and cam I'm going to go with! Thanks for your help!
