Help, Big Cam Need Advice!!!!!!!!
Yeah, I meant to and forgot to ask about that. 12 degrees of split is huge. I'd bring the intake up and the exhaust down, anything. Or at least bring the exhaust down a little. Mine's a 237/242, that is a more common split. 12 is just a ton.
Originally Posted by DriveFastAlways
how will this affect everything?
Originally Posted by Beast96Z
If you hold the exaust valve open to long, you could infact induce a vacume. In this case, you would pull raw/unburnt fuel into the exaust/header causing combustion in the exaust path. This would cause poor performance because a portion of what should have been burnt in the combustion chamber in now being burnt in the exaust were it will only cause high exaust temperatures. In essence, your somewhat over scavenging. You want your motor to move air as equaly as possible and you want your combustion to take place in the combustion chamber, not the exaust path.
lol so ill get all sorts of flammage out my side exhaust
