Roller Rockers??????????
Old May 12, 2005 | 07:22 PM
y2k2z28's Avatar
Default Roller Rockers??????????
What benefit from installing larger ratio roller rocker on a stock ls1......what ratio would be the best bet???
Old May 12, 2005 | 07:49 PM
blkZ28spt's Avatar
My $.02: Don't bother with higher ratio rockers. Get a cam instead.
Seriously, going with higher ratio rockers will limit your cam selection in the future and the hp/$ just isnt very good.
Old May 12, 2005 | 10:02 PM
y2k2z28's Avatar
Thanks did not realize that it would limit the cam shaft choices in the future.
Old May 12, 2005 | 10:03 PM
blkZ28spt's Avatar
If you read the descriptions of a lot of cams it will say "due to the high ramp rates, the use of high ratio rockers are not recommended..." or something like that. They also can give you more lift and interfere with the total lift and PTV clearance.
Old May 12, 2005 | 11:32 PM
Wnts2Go10O's Avatar
jus get the crane qwick lift 1.7's theyre pretty nice
