Lifter Tool??
Old May 12, 2005 | 11:54 PM
94redz28's Avatar
Default Lifter Tool??
I am going to do my cam install this weekend and i forgot about geting the tool you put in the motor to hold the lifters up. My question is does anyone know if a peice of round bar would work the same? If so what size would i need. Thanks guys.
Old May 13, 2005 | 12:09 AM
Brandon Boomhauer's Avatar
most use a cheapo round bar, 1/4 or 5/16 should do the trick.
Old May 13, 2005 | 12:27 AM
blkZ28spt's Avatar
You can just use a simple wooden dowel rod too. Very popular.
Old May 13, 2005 | 02:25 AM
markp03's Avatar
thats waht i used...two wooden dowels
Old May 13, 2005 | 02:57 AM
PREDATOR-Z's Avatar
I wouldn't use wood. Too dangerous if it breaks inside.
Aluminum is the way to go.
Old May 13, 2005 | 02:58 AM
Checkmate's Avatar
Used 5/16 rod, had to grind them down just a little.
Old May 13, 2005 | 03:20 AM
markp03's Avatar
how are you going to break them? just use your head and your good
Old May 13, 2005 | 05:14 AM
PREDATOR-Z's Avatar
Should I wiggle my ears too???
Old May 13, 2005 | 01:58 PM
~JOSHUA's Avatar
I did TONS of searching on this before I did my cam a couple months ago. I ended up getting 1/4 aluminum rod for Home Depot for $3.xx each. Took a file to the ends and rounded and smoothed a bit, stood up next to the cam and gave an extra 4inches and made a bend. Mark with a scratch where the cam stops next to the rod so you'll know that the dowel has slid far enough to snag ALL the lifters.
Old May 13, 2005 | 02:12 PM
Good idea with marking the lenghts firehawk!
Old May 13, 2005 | 03:30 PM
Jeffs99SS's Avatar
I did the same. FWIW, on my '99 block, 5/16" steel rod fit on both sides of the motor. The only grinding was rounding off the tip that goes into the engine. I didn't grind anything along the length. I also used the cam to measure length, then just bent a handle.
Old May 13, 2005 | 04:43 PM
2001CamaroGuy's Avatar
second......
the lifters don't weigh anything compared to the stregth of a good hardwood dowel.......
I personally have never used a tool (other than pin mags down the pushrod holes) to hold the lifters up......
Old May 13, 2005 | 05:12 PM
~JOSHUA's Avatar
I didn't want to use magnets because
1) the cheapest I found was $6.49 each
2) cheap magnets can seperate and now you have the magnetic tip stuck to the top of the lifter... take the heads off to get it back.
3)sliding a rod in place is easier than making sure 16 magnets are popped into place correctly.
Old May 13, 2005 | 05:17 PM
blkZ28spt's Avatar
I definately prefer and promote using rods vs pen magnets as well.
