Will i have any kind of clearance issues with this setup?
Old May 13, 2005 | 12:39 AM
5.3litre's Avatar
Default Will i have any kind of clearance issues with this setup?
ok here is my setup..i gotta 6.0 bored .030 over i got lunati rods that are 6.125 in length diamond pistons, stock crank, patriot heads and a 231/237 tsp cam...i was just wanderin if i will have any clearance issues..i was worried about the piston/valve clearance since the rods are 6.125 ...will i be ok or what do you guys think? thanks
Old May 13, 2005 | 08:01 AM
5.3litre's Avatar
anybody?
Old May 13, 2005 | 08:03 AM
BrentB@TEA's Avatar
I doubt you will have a problem but you should always check.
Your pistons have valve reliefs in them already correct? If so you should be fine.
Old May 13, 2005 | 08:37 AM
JZ'sTA's Avatar
Yeah if those are 2cc valve relives you will have a walk in the park.
