Which Cam to get???
Old May 15, 2005 | 01:45 AM
1LE LS1's Avatar
Default Which Cam to get???
got an '02 SS and wantin to do a cam swap but will have to wait for heads later on
just wanna know what the biggest cam i can go with for my car,its an automatic, so whats the biggest before i will need a convertor???
i drive the car most of the time but i still want a lopey idle, i deffinatly want it noticable not just a lil bump
or what would be the best to go with if i had a stall??? what all supporting mods would i need???(tuning,injectors,plugs,etc....???)
still want drivability but good sound and performance at the same time
thanks
Old May 15, 2005 | 01:58 AM
blkZ28spt's Avatar
Same thing that everybody with an auto is told: Get a converter first.
For supporting mods it is recommended to get subframe connectors (SFC), converter, shift kit, trans cooler, trans temp gauge, lid, full exhaust (headers, preferably longtubes or at least mac mids and either a y-pipe and cat-back or duals), and drag radials first.
If you get all those things you will have a good base upon which to add a cam. A few suspension mods wouldn't hurt either. Lower control arms (LCA's), torque arm (TA), and/or a panhard rod.
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Most important link, in relation to this post, from his sig: http://www.ls2.com/forums/showthread...threadid=19550
Old May 15, 2005 | 06:19 PM
Firehawk441's Avatar
I agree. don't even think about a cam without a converter. Also, a lopey idle with an automatic is not your friend.
Old May 15, 2005 | 10:45 PM
blkZ28spt's Avatar
ESPECIALLY without a converter. But with one....
My car is an auto and lopes like a ****.
