MPP2 Power Plates
Also, where is an ideal place to ground the black wire?
I dont want to have too much wire cause i wouldnt want the battery to drain......
I spliced the power wire to the most accessible pink (switched 12v) wire I could find under the dash and wired the ground to the bolt on the driver's side that holds the console on. The switch/LED are also in the ashtray.
Yes, the light in the ashtray always stays on. Hope this helps.
Thanks.
