solid roller cams
Old May 16, 2005 | 01:08 PM
Z28SPD's Avatar
Question solid roller cams
what are the advantages?
Old May 16, 2005 | 01:30 PM
sb427f-car's Avatar
SSU'S Vice Mod
Mainly strenght to stand up to big lift @ high RPM. If you're not planning on running any more than about 7600 RPM, you should be fine on a hydro roller, especially if you're @ .600 or less. The big dissadvantage is valvetrain noise and the need to constantly lash. That's the rough answer, but what's your application, as I'm sure the more experienced engine builders and assemblers can better answer you.
Old May 16, 2005 | 02:22 PM
Ben R's Avatar
7,600 RPM is a lot for a hydraulic roller lifter. Especially with big spring pressures.
A properly setup solid roller valvetrain will not need to be checked but every 2 to 3 thousand miles. And unless you've got some sort of parts failure, you'll do just that, check it, not adjust it.
Old May 16, 2005 | 02:25 PM
BTL FED's Avatar
Also because of the faster ramp rates a big solid roller will idle much better than a hyd roller of the same size.
Old May 17, 2005 | 04:49 PM
Z28SPD's Avatar
right now ive got following performance mods:
MTI stage 2 heads
comp cam
l/t headers, borla
3600 converter
lid
90/90 setup
u know all the bolt ons and what not.
im planning on building a stroker most likely 408 in the coming year or so and i was thinking about going to solid roller.
car sees very minimal daily driving, less than 50 miles a week if that. Sees the track mostly.
