LS6 cam in LS1
Old May 16, 2005 | 10:52 PM
racinbird's Avatar
Default LS6 cam in LS1
After search, I really didnt find a solid answer...
I have a LS6 cam, I know, small cam not worth it, however I bought it used and cheap, I will be doing the labor myself, anyways
Do I need to change push rod length to do this swap properly? I heard something about smaller base circles on LS6 cams and longer valves on LS6 heads to compensate. Anyone? thanks
Old May 16, 2005 | 11:42 PM
2xLS1's Avatar
Some will say yes. Most will say no. I've installed 4 LS6 cams all with stock P/Rs with no problems.
Old May 17, 2005 | 05:11 PM
F-Body4Life's Avatar
You might as well change them while you are in there
Old May 18, 2005 | 02:00 AM
Chris81's Avatar
I just used stock length Manley pushrods, no problems.
Old May 18, 2005 | 06:01 AM
JohnnyStorm's Avatar
The LS6 valves are .6mm longer to compensate for the reduced base circle of the 02 LS6 cam using stock 7.40mm pushrods. I used Manley 7.45mm pushrods that came in a sponsors kit. GM was concerned with valve train geometry when they designed the 02 LS6.
