Can clogged cat damage motor?
Old May 20, 2005 | 07:45 AM
LS1mtZ's Avatar
Question Can clogged cat damage motor?
I have been running with the P0420 code for awhile so I assuming I have a clogged cat. Car was running fine just had SES. However, recently I have been getting a really rough idle. Sounds almost like it's knocking at idle but the scanmaster shows nothing. Doesn't do it when cold. Once driving the sound seems to be gone, but at WOT I get about 3* of knock. Did I wait to long to get cat fixed and it melted something?
Old May 20, 2005 | 08:12 AM
zamboxl's Avatar
its possible but damn man thast some f uped cats u got there, just rip em out and run without them.
talk to JZ'STA he lives near u he can help u out with that, just send him a pm.
Old May 20, 2005 | 08:48 AM
wrencher's Avatar
wrencher
P0420 is a catalyst inefficency code. It usually is not caused by a clogged cat. Usually set by a degraded cat, or a fuel trim issue.
Old May 20, 2005 | 09:43 AM
LS1mtZ's Avatar
What is a degraded cat? My LTFT's are anywhere from -4 to -10.
Old May 20, 2005 | 10:22 AM
GuitsBoy's Avatar
A cat that does not function properly for any number of reasons. If you cat was truly clogged, then egine would be running rougher and very sluggish. Either get a new cat or some o2 sims, or simply turn off the codes via tuning.
