Big cubic inch A4 daily driver question
Old May 20, 2005 | 08:44 PM
DBN's Avatar
DBN
Default Big cubic inch A4 daily driver question
Which cam, gear, and convertor are you running in your "daily driver"? Are you pleased with this combination?
Old May 20, 2005 | 09:03 PM
JZ'sTA's Avatar
1 car is a 3 speed with a 373 gear. 3800 stall.
The converter is great. The 3 speed sucks and the 373's should be 323's to be more gas efficient.
The other is a FLP 4L60E with Yank 4200 or Yank 3800 (when I decide to run spray I switch verters) 373 gear.
Again maybe a 342 would be a better gear for the street but the 373 is fine.
3rd is a mostly stock Z28 with a 4L60E. 273 gear, and 3600 stall.
Great to drive. If I use a larger converter I would probally switch to a 323 gear.
Old May 20, 2005 | 10:21 PM
JZ'sTA's Avatar
Sorry the 3rd car is stock cubic inches.
The first 2 setup were larger cubic inch setup's.
