Cam Carnage
Old May 24, 2005 | 01:59 AM
HSV-GTS-300's Avatar
Default Cam Carnage
Hi there. I'd love to hear from you guys as to what can cause damage like this.
The engine is a Callaway C4B. Basically a LS1 stock bottom end with heads and cam. 400hp.
From what I can gather the cam is something Crane supplied to Callaway in about Yr 2000.
212/222 .560/.569 117LSA
Car is daily driven, 43 000 miles, always Mobil 1, never raced. Has no other mods. Has broken a rocker arm and a valve spring at different times before this latest deal. Valve springs were special ovoid section originally but now the latest LS6 springs are fitted.
These are pics from another engine with identical damage to what I have here now. I believe the term used is spalling.
Anybody seen this before in a similar situation , and more importantly what is the likely cause ??????
Old May 24, 2005 | 02:17 AM
CAT3's Avatar
Restricted User
Hmm. Good one.
Uneducated in this but will give a shot or two.
1) Spring pressure to high
2) Improper filtering of oil, stuck the roller wheel on cam lobe
3) bound up roller wheel
I'm not too good at this guessing game, hope I'm close though.
Old May 24, 2005 | 03:03 AM
Ok thanks for your input.
Some more info:
1) Original springs installed in the engine were selected by Callaway....these engines do have a history of breaking those. About 1500 miles ago one spring broke in my engine and all 16 were replaced with GM dealership supplied LS6 springs. Green stripe I think.
2) Car has had regular oil changes as per GM service manual , at the most every 6000 miles. Always Mobil 1. Filters as per manual. Always serviced by GM dealership.
3) On mine both roller wheels and lobes were damaged in the cylinder closest to the firewall on what would be the USA drivers' side. Two wheels were pitted same as the pic and had noticeable flat spots. They both still turned fine with no noticeable noise or wobble when rolled with a finger though.
4) Car is M6
Old May 24, 2005 | 03:19 AM
DaleMX's Avatar
Maybe the hardening on the cam was not done properly or the steel was contaminated during manufacturing.
Old May 24, 2005 | 03:29 AM
Byter's Avatar
Check out what happened to me (page 2) https://ls1tech.com/forums/showthrea...ght=cam+damage. This was on a Lunati cam with over 60K miles.
Old May 24, 2005 | 04:42 AM
XTrooper's Avatar
That's possible, but I think the spalling would have been more widespread and not isolated as it is in this case. I think the problem, whatever it was, originated in the valvetrain.
Old May 24, 2005 | 11:42 PM
CAT3's Avatar
Restricted User
Since you have the cam out, have you checked the bearings, making sure non had turned it the journals? no gouging etc?
Old May 25, 2005 | 12:00 AM
oange ss's Avatar
I'm gonna blame it on the lobe...not hardened correctly...yes all the lobes are hardend at the same time before final finishing but if there was junk metal in that lobe then it wouldnt matter and i believe the correct term would be galling due to lack of lubrication or metal fatigue due to distress
Old May 25, 2005 | 12:13 AM
No I don't have the cam out of mine yet. The pics I posted were of a very similar case in someone elses identical engine.
I have only viewed my roller lifters and looked at the cam by peeping down the lifter bores. 2 of my rollers and 2 lobes appear the same as those pics.
I'm wanting the dealership to pull the sump to check bottom end bearings and renew the oil pump as a very minimum. They dont even want to do any of that.
I already got loose needle rollers in the sump from the broken rocker that happened 2 years ago. The magnet picked up some needles 12 months after that episode but maybe not all of them. Since then I've had a broken valve spring and now hard facing is missing from cam and lifters. So who knows what else is in there ????
Old May 25, 2005 | 12:43 AM
CAT3's Avatar
Restricted User
Sounds like there was a QC issue with these cams. Especially if you have two of them (your and your buddies).
I doubt the needle bearings has anything to do with the cam facing or the valve spring. But I would consider the car jinxed
