Cam question? What is your advice
I am going to put a cam in my 01 SS M6, car. I want a cam that will give me the most power gains with a stock head/stock cube motor, I will drive the car quite a bit but it does not need to be my daily driver (I can put up with a lumpy idle and a car that shakes, even on a daily basis though). I don't want to have notch the pistons or anything. I will be going with a different rear end when my 10 bolt blows up and will get whatever gear matchs my cam best. Tuning is not an issue as I have access to a chassis dyno and sombody to help with the tune. So let me know what you guys think, spring suggestions are also appreicated.
Thanks
j/k, I come off rough a lot.
I did answer your question though.
Edit: BTW, if you get a Trex or G5X4 make sure you get the tune NAILED for street driving. And you will want gears. You might want to go a little smaller. I drive the MS3 daily in an auto with 3500 stall and 3.23's and it's perfectly fine. (I am upgrading to 4000 stall right now, and 3.73's later)
IMO, I don't know if you'll like the T-Rex or anything bigger than the F-15. I'm a "big cam" kinda guy and the F-15 is about the max I'd go on the stock cubes (236/239 @ .050") Anything bigger is going to severely hurt your low end. If you decide to go with the F-15 or bigger, I'd STRONGLY suggest you go with a 4.30 gear.
Mike
