ARP crank bolt
Old May 26, 2005 | 04:32 PM
777's Avatar
777
Default ARP crank bolt
Is the ARP crank bolt reusable. I'm thinking about doing a head/cam swap and wanting to know if my current ARP bolt can be reused.
Old May 26, 2005 | 04:34 PM
Xtnct00WS6's Avatar
You can probably reuse the old bolt for the crank, but the issue is getting the crank pully off. You'll need a longer crank bolt for a cam swap.
Old May 26, 2005 | 05:50 PM
Cal's Avatar
Cal
Yes, the ARP crank bolts are reuseable. It's also helpful to have another bolt with a cone shaped hole in the head for the wheel puller to drop into. The special long bolt or the stock bolt could be used for this.
Old May 26, 2005 | 07:48 PM
ScreaminDemon's Avatar
The LS1/LS6 5.7 and 6.0L ARP balancer bolt kit has the indentation for the puller. It's stock # is 234-2503.
Old May 31, 2005 | 07:55 AM
777's Avatar
777
I've already done an oil pump/timing chain install so I already know how to take the pulley and stuff off. I just wanted to know if i could reuse it. Thanks guys.
